bizhub 600 jams in ADF WHEN DOING 2-SIDED accomanied with a noise j6202
  • fearless
    • Jun 2015
    • 20
    [Jamming] bizhub 600 jams in ADF WHEN DOING 2-SIDED accomanied with a noise j6202
    Hello Everybody
    has anybody dealt or seen this issue?
    • 23008
    Re: bizhub 600 jams in ADF WHEN DOING 2-SIDED accomanied with a noise j6202
    Maybe 66-02? I think you would have discovered that there is no 62-02 in the manual. =^..^=
    • allan
      RTFM!!
      • 5462
      I had that on a B601 it drove me mad. found that the paper would seem to jam into a gate on its way back to the glass just before the second scan. I remember the code and the noise like a belt jumping.
      It drove me mad, i changed the DF board with the same result then the entire DF with the same result. Also did firmware.
      To get it running i had to file away a part of the gate.
      Whatever
      • fearless
        • Jun 2015
        • 20
        Thank you guys...there is actually a jam code for ADF ON P.412 ON SERVICE MANUAL . is it the turn over guide or the paper guide ,that is sitting on Slit glass?
        Thanks a whole bunch
        • allan
          RTFM!!
          • 5462
          In my case the first gate after switchback.
          Whatever
          • fearless
            • Jun 2015
            • 20
            Thank you Allan.
            i will try that.
