bizhub 751 Dead Finisher
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Dead] bizhub 751 Dead Finisher
    We have a bizhub 751 with a finisher on it that has been running fine for a long time. Just recently the finisher appears to be dead. The machine operation panel does not respond with indication when the finisher door is opened. During Boot-Up the finisher does not run ANY motors, paddles or rollers. The machine will boot all of the way up and make a copy, however it just jams upon entry of the finisher with no codes (other than jam). There IS 24 volt and 5 volt going to the finisher. Any thoughts? Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • SAR
    • Jul 2009
    • 203
    Re: bizhub 751 Dead Finisher
    I have 2 of these finishers doing this! I was hoping you found out what the issue was on yours and might be able to tell me something.
    Thanks!
    • tech51
      • 846
      I had one do this. It turned out the firmware had gone from the fns control board. I re loaded the fns firmware and it was fine afterwards.
      • allan
        RTFM!!
        • 5462
        Are u sure those connectors between the machine and finisher is ok. It's easy to mess them up by disconnecting and pulling the finisher away. I have done that before.
        I would do a point to point test on the connectors.
        Next would be to look for ICP's then to swop the control board.
        There should be a lot of unused machines around. I swop out and scrap the entire finisher if it gives trouble.
        It could be on the machine side as well.
        Whatever
        • MFPs R Now PCs
          • Jul 2011
          • 156
          We have replaced the PWB Board for the punch unit and everything was fine for a week and then the same thing occurred. So we disconnected the punch unit permanently and discussed with customer for costs associated of replacing finisher, geez... THANK YOU TO EVERYONE!
