BizHub C-451 print quality problems
  • aAandy
    • Apr 2012
    • 370
    hello everywon
    received an email from a client with samples of what their machine is doing
    normal prints, then washed out prints, then registration problem, then cleaning blade problem,,,,, client turns the machine off/on & it runs several hundred prints OK,,,, once it starts playing up again they turn it off/on and can print another few hundred
    this machine has had the K drum unit modification fitted to ensure it is correctly seated
    any pointers would be very much appreciated
    thanks in advance
    Bizhub C451a.pdf
  • Albonline
    • Sep 2008
    • 1151
    Re: BizHub C-451 print quality problems
    this usually turns out to be a hv arc, is the inside of the unit filthy with developer?
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      i've had that before too on a c550.
      If any of the imaging units are tracking developer on the belt and it ends up in your 2nd transfer roller it will cause this.
      junky old machines like the c451 do this alot especially if the transfer belt is leaky at the waste section it destroys the yellow iu regularly. Among many, many other causes ... none of which are cheap to fix
      • aAandy
        • Apr 2012
        • 370
        i've not been to the machine as yet, though i will check for dev spillage & HV arcing, ITB cleaning unit & 2nd transfer roller
        thanks for the tips gents
