ok I am done with C451's
  • konica7022
    • Nov 2008
    • 132
    all c451's that i have have the same issue same head ache BLACK IU
    1. The First Pages shadow gets printed on the Second page
    The black color gets white grains on it
    i had 6 K IU, all of them have the same problem,either shadow or Grains
    so i had it!! i am switching
    is bizhub C452/652? a better alternative?
    or should i go for Canon 5185i or canon c4030
    Or Taskalfa c250i
    Which is MOST reliable?
    kindly advice on both B/W & Color from your experince
  • Zackuth
    • Aug 2009
    • 448
    Re: ok I am done with C451's
    We have 4 C452's in the field and have very little issuses with them.
    You're headaches will not get any better if you get a Kyocera 250ci--or any Saturn type machine.
    Can't comment on the Canons, we don't any of those under maintenance.
    If at first you don't succeed, redefine success
    • allan
      RTFM!!
      • 5459
      Or Taskalfa c250i
      A C360 is the very cheap to run.
      Whatever
      • copier tech
        • 8101
        I agree the C451 k IU are so problematic, dumping dev the worst fault, but on some the small bracket helps.
        The C452/C552 are a great work horse, never had any real issues, all units seem to hit life & beyond!
        In my opinion way better than Canon, their drums etc only just hit life & thats short as it is!
        • konica7022
          • Nov 2008
          • 132
          ok i got OCE 4522c which is same as bizhub c452
          i have yet to install it
          here are the print outs and consumable info ... don't know what condition it is in ?
          The black toner cartradge seem to be empty wheni take it out but on the screen it shows half full?
          • Max
            • Oct 2011
            • 546
            If you want to change go for the latest c654e.The c452 are quite old now but much much better than the c451. I worked on various colour manufactures and i have to say starting from c360 range and up they are far superior to ricoh, canon,kyocera. Not 100% sure on the latest generation from other manufactures, but if history if anything is to go by I would stick to konica just not the c451.
            • ChrisG
              • Oct 2013
              • 181
              Agreed. The "2" series was better but until you hit the "4" series, you're still going to be chasing a lot of noises from the fuser drive area. As far as the Kyocera idea, I'm not sure what they're newest latest greatest is now, but the 250/300/400/500c series wasn't worth the time it would take to drop them off a cliff.
              • konica7022
                • Nov 2008
                • 132
                4 series sounds and looks good most probably will work well too, but its way out of my budget (<1k$)
                i meet another dealer he said he imported some DEMO machines from JAPAN both canon and bizhub including c452 all of them used for display purpose and less then 1k copies ONLY
                but he is selling the biz hub for 3.5K$
                and canon starting from 2K dollars
                these machines although not used but still are 5 to 7 years old! but would be better i guess
                if this OCE 4522c gives me any problem i will, call him and try those too
                what possible problems can i face with c452 and based on the counter print i attached what do you think about the machine i bought
                • darry1322
                  • Oct 2010
                  • 817
                  Now, Now ..... once you replaced all the drums and developers with updated units as well as the newer transfer belts and fusers and firmware and drive motors , the machines weren't too bad.
                  • Bob Wescott
                    • Sep 2013
                    • 14
                    Or Taskalfa c250i
                    forget the KYocera 3-digit ci's! Haven't had your C451 problems, but the newer Kyoceras are quite happy. 4550 ci. 5550ci run well, give good yields and low costs per color page. 6550ci is a champ. Kyocera dual-scan feeders are superb.
