Problem bizhub series 4 when connected network
  • sangcom
    • Jun 2009
    • 45
    Hi all
    We have a problem bizhub series 4. We have two clients are in different locations (C224,C284e) both machine have issue same.
    When have to connected lan network the machine have the symptom the panel freezes(It's like trying to connect to something.) and meanwhile when unplug lan cable the machine is normally.
    (If connected directly to computer not found, this symptom.)we have video of this symptom.
    Thank you
  • darry1322
    • Oct 2010
    • 817
    Re: Problem bizhub series 4 when connected network
    This has come up before. Some techs put a network switch between the copier and the customers network to resolve.
    The three I found with this problem were turned over to and resolved by the customers IT dept.
    • hotfuser
      • 180
      Originally posted by sangcom
      Hi all
      Thank you
      Are these machines running DHCP?
      it looks like there may be something still in the print queue or an IP conflict.
      • allan
        RTFM!!
        • 5462
        Try changing the network speed from auto to 100mbs duplex.
        I have fixed the same issue with a B36 by adding a network switch.
        Whatever
          • 23009
          Are these machines authenticating, or using account track? =^..^=
