Bizhub 501 Trouble Code C-3501
  • noobie1
    • Jun 2015
    • 48
    [Error Code] Bizhub 501 Trouble Code C-3501
    Hello, i am freshmen printer technician, I need some help to resolve this error code C-3501 appear on our photocopier? What this error and how troubleshoot? Please help me, i need your kindness heart..?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 501 Trouble Code C-3501
    Its a fusser code. Switch the machine of keep the utility button in and wait a bit for the trouble reset button to pop up press that and follow the instruction to restart the machine.
    Its bad power from time to time that would cause that. If it does not clear then something in the fusser is broken.
    Whatever
    • noobie1
      • Jun 2015
      • 48
      Could you please give some steps on how to reset the error code? If the issue is persist what is the best thing to do?
      • allan
        RTFM!!
        • 5462
        Did you do the trouble reset? If that does not work it could be a broken heater lamp a thermal fuse or a busted thermistor.
        What have you done so far?
        Whatever
        • noobie1
          • Jun 2015
          • 48
          @allan, Thank you very much for help its big help on myself to resolve the issue, i really appreciate your help. You're too kind person.
          I just follow your instruction (Its a fusser code. Switch the machine of keep the utility button in and wait a bit for the trouble reset button to pop up press that and follow the instruction to restart the machine.) I did it well.
          God bless you Allan, i hope many people like here in the forum. Also im be thankful to the moderator/hosting administrator of this forum. God bless this forum.
          • allan
            RTFM!!
            • 5462
            It a pleasure. I agree this site is a valuable resource and help.
            Whatever
            • peter@digitalswebsite.com
              • Aug 2012
              • 29
              Just to add my 2 cents, if the web supply runs out, it will cause the fuser to bind, and can cause the same code
              • Polygon
                Hi Allan:
                im new on konica minolta and i have the same error 3501 on my konica c7000p.
                i already change the TH1 sensor, how can i reset or errase the code.
                I will be eternally grateful
