Hello, i am freshmen printer technician, I need some help to resolve this error code C-3501 appear on our photocopier? What this error and how troubleshoot? Please help me, i need your kindness heart..?
Bizhub 501 Trouble Code C-3501
Tags: None
Re: Bizhub 501 Trouble Code C-3501
Its a fusser code. Switch the machine of keep the utility button in and wait a bit for the trouble reset button to pop up press that and follow the instruction to restart the machine.
Its bad power from time to time that would cause that. If it does not clear then something in the fusser is broken.Whatever -
Could you please give some steps on how to reset the error code? If the issue is persist what is the best thing to do?Comment
@allan, Thank you very much for help its big help on myself to resolve the issue, i really appreciate your help. You're too kind person.
I just follow your instruction (Its a fusser code. Switch the machine of keep the utility button in and wait a bit for the trouble reset button to pop up press that and follow the instruction to restart the machine.) I did it well.
God bless you Allan, i hope many people like here in the forum. Also im be thankful to the moderator/hosting administrator of this forum. God bless this forum.Comment
Just to add my 2 cents, if the web supply runs out, it will cause the fuser to bind, and can cause the same codeComment
Polygon
Hi Allan:
im new on konica minolta and i have the same error 3501 on my konica c7000p.
i already change the TH1 sensor, how can i reset or errase the code.
I will be eternally gratefulComment
