Biz Hub 601
  • antone
    • Oct 2014
    • 344
    Biz Hub 601
    Toner recycle pipe clogging up! Replace gears...even complete processing unit
  • allan
    RTFM!!
    • 5462
    Re: Biz Hub 601
    Is the front drum cover still there?
    Whatever
    • Jazzwcs
      • Jun 2012
      • 40
      Re: Biz Hub 601
      Sounds like the motor (M2) may be the issue since you replace the processing unit. The only other things that would cause a backup in the pipe would be bad gears on the dev unit or toner recycler clutch (CL14) not firing. Do load checks 41-3 (M2 at LS357) to see if the motor turns smoothly. Also check 54-0 (CL14) fires properly. After that, you are more than likely looking at a faulty PRCB.
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Re: Biz Hub 601
        I have changed a lot of toner recycle clutches.
        • allan
          RTFM!!
          • 5462
          Re: Biz Hub 601
          I just unplug the clutch from day 1, so it just keeps running all of the time. I have seen a couple where the drum cover was missing. The pipe can unclip with handling giving the toner no where to go.
          That drive is strong enough to break the auger.
          Whatever
