7255 Error SC56-03
+ More Options
Posts
  • selig67
    • May 2008
    • 156
    7255 Error SC56-03
    cant find this in the manual or on Konica solutions.. anyone have any idea?
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    Did this just spontaneously appear for the customer, or during/after a service call?
    • selig67
      • May 2008
      • 156
      board replacement
      had to replace the main board.. I took it off a 7272. I kept the original NVRAM. I found that 56-04 is a serial number issue, but I did the procedure to reset the serial number and it had no change
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        That board has 7272 firmware on it. As far as I know, the FW cannot be overwritten. IOW, useless to a 7255. Sorry.
        • redhotrob
          • 69
          CAUSE: There is no firmware installed on a new Printer Control Board.
          SOLUTION: Flash the machine with the latest
          • RockETop
            Curmudgeon at large
            • Apr 2007
            • 171
            If it was in a 7272, wouldn't there be FW, just the wrong type? I know that 7165/55 boards cannot be swapped once written.
            • selig67
              • May 2008
              • 156
              firmware problem
              the ISW wont even connect.. going to steal a board from a 7255 and see what happens.. thank for all the help
              • nmfaxman
                • 1702
                The list of differences shows control board exclusively for each machine because of CPM.
                • onabike
                  Have changed a 7155 control board to a 65 once a while ago. The key was to start an isw and interrupt the download as soon as the graph shows the download in progress. then reflash with the firmware you want the board to become. Sorry, but I cannot remember if it was the Image or Control firmware.
                  • selig67
                    • May 2008
                    • 156
                    the ISW wont even start.. just flashes a "connecting" message. the machine shows an error 41
                    • RockETop
                      Curmudgeon at large
                      • Apr 2007
                      • 171
                      That error is for flashing a board w/ the wrong, different firmware. That confirms my earlier assumption.
