C3110 no start the Display, Panel and scanner no function.
  • freixi
    • May 2009
    • 53
    hi Guys
    I have a bizhub C3110 and in turned one I see on the screen only the pixels (no backlight)and the controll pannel get no answer, scaner also does not come on. After repeatedly off and on she goes complet again. In turn, the man listens componenten normal as ever, only the upper part does not turn on, no lamps.
    what can I do?
    last Firmware Update not results.
    Best regards
    Freixi
  • hmp
    • Jul 2010
    • 8
    Re: C3110 no start the Display, Panel and scanner no function.
    Hi Freixi
    How did you go with this?
    We are having the same issue as we speak and the Tech had escalated this to Konica.
    They tried the firmware and then also a format of the SSD. Konica have advised to replace the SSD board.
    cheers
    • freixi
      • May 2009
      • 53
      Hi,The post I had already forgotten.
      I changed to guarantee this part.
      Replace PWB PN: A6DTH01004
      problem is solved
      The SSDB is the complet board (PWB+PRCB) ??? no can see in the Parts Manual.
      change PRCB= not solved
      change PWB= solved
      Many thx
      • jwai
        • May 2018
        • 506
        So, you finally solved this issue by replaced the MFPB of SSDB?
        • jwai
          • May 2018
          • 506
          problem is solved
          change PWB= solved
          Many thx
          Freixi[ATTACH=CONFIG]30634[/ATTACH]
          #5 on the manual is the part number of SSDB.
