Bzzhub c452 baclk IU or Transfer belt?
  • sauce_boss
    • Oct 2011
    • 26
    #16
    Re: Bzzhub c452 baclk IU or Transfer belt?
    It's the transfer roller, replacing it should take care of the issue.
    • allan
      RTFM!!
      • 5462
      #17
      Originally posted by EarthKmTech
      i don't remember the last time i was able to reuse a dv-612 on a 652 series, they are always visibly worn in the centre by the the time the first drum life is up. I always change the drum and dev a pair now. Some techs/companys may just ignore the poor print quality most noticeable on solid blacks and reuse it but I cannot.
      On the other hand the dv-711 on the big 4 series does actually consistantly last life, I dont know what they changed but it made a difference.
      Yea, the 4 series is much better i can get up to 1.5M from a tank.
      Whatever
      • Mitch Barron
        • Mar 2013
        • 180
        #18
        I would guess the TR also...hope you get it sorted!
        • konica7022
          • Nov 2008
          • 132
          #19
          Yes it is the Transfer Belt, i pulled it out and checked several times and once found the exect same stains/patterns on TB
          i have asked the dealer to replace it.
          hopefully he will replace or i will change the cleaning blade for the TB
          • konica7022
            • Nov 2008
            • 132
            #20
            ok i got the replaced TB which is not in that good condition but the machine is now working fine
            those patterns are gone now
            thanks for all those who replied and who watched as well
            • Markrich130
              #21
              The transfer roller voltages have been revised by Konica Minolta through special firmware for this issue.
              A new transfer roller may help resolve the issue, sometimes only for about a month. The special firmware version is GCJ.
              • Desert Rat
                • May 2008
                • 1089
                #22
                Markrich130,
                Thank you for that post. I just sold a BHC452 a month before this post.
                Does this happen on all BHC452?
                DR
