Bizhub c652 TCR level Black to High C-2558
  • freixi
    • May 2009
    • 53
    Morning all
    Bizhub C652 errorcode C2558
    y have the TCR level in Black unit to High (11,50) normal is ~7-8
    its possible this to reduze the TCR level?
    Y have the level in service mode +3 and the max level to +10 and not result..
    many thx for help
    Freixi
  • Max
    • Oct 2011
    • 561
    Re: Bizhub c652 TCR level Black to High C-2558
    i would say your dev is over life or there is a blockage from toner hopper to your developer unit. Manually add toner and if the value changes then its probably the dev.
    • freixi
      • May 2009
      • 53
      Thx Max,
      Ok, add toner to developer Unit?
      if that is too high is missing toner ?
      I thought if that is too high that he has too much toner.
      Y testing and report.
      Thx Max
      • freixi
        • May 2009
        • 53
        Hi Max,
        many thx, add toner to veveloper and the bizhub its runing normal.
        The Level ist ok..
        thx for reply
        Freixi
        • allan
          RTFM!!
          • 5462
          You can try to de-tone it, then reset it but the real problem is there is not enough developer left.
          Whatever
          • freixi
            • May 2009
            • 53
            Yes, the developer unit did not have enough starter.
            Y change the developer unit and the bizhub running normal, TCR ~7.4
            freixi
            • copier tech
              • 8174
              Just to add you can save all the old image units inc black dev unit then if any unit has a print quality issue due to low dev you can easily top up the toner/dev mix from the old units works great (assuming the drum isnt worn)
              • freixi
                • May 2009
                • 53
                nice tip
                thx...
                y have 3 or 4 Developer units
                many thx
                Freixi
