C224e brabdnew and problems on Imaging (K)
  • freixi
    • May 2009
    • 53
    Hello,
    Y have a c224e brabdnew, count 137 Pages and have div. errors.
    P-5 IDC Sensor (Front)
    P-22 Color Regist
    P-9 Drum /Development Unit (K)
    Have in stat confirmation under Level history (TCR) all colors normal and the Black TCR is 0.00%
    the pages are always brighter
    Have manual add toner in service mode and not result.
    Have changed the UI K to brandnew from Konica Minolta and not result.
    What can I do about it?
    Many thx
    Freixi
    Please help mee.
    • 14423
    Re: C224e brabdnew and problems on Imaging (K)
    What do you mean by "the pages are always brighter"
    Are you getting any error codes besides the P codes?
    Try replacing the dev unit.
    • freixi
      • May 2009
      • 53
      all pages no intensity in Black.
      Y have a brandnew Imaging Unit and not result. see (atachment)
      SKMBT_C220_15071512380.pdf
      Y have a Open ADF and klick to copy.. Normal is the page compl. Black.
      This is not Black, its gray and not tensity.
      The error codes its p- codes in service mode. I not can see in operator mode errorcodes.
      Many thx
      Freixi
        • 14423
        There aren't imaging units on this model. The drum and dev unit are separate. Pull out the black dev unit and turn the mag roller to see if there is any dev on it.
        If not then you may need a high voltage board and a new dev unit.
        Have you called Kon Min tech support?
        • freixi
          • May 2009
          • 53
          Konica Minolta I can not reach anyone in the moment.
          I will try to remove the DEV and install a new one. I tell then what has brought .
          I've never removed a DEV from a c224e . Is that easy ? Remove the screws forward enough?
          Thx
          Freixi
          • hotfuser
            • 180
            [ATTACH]29877[/ATTACH]
            Many thx
            Freixi
            it looks like the HV has failed as the dev is being sucked from the unit.
            • allan
              RTFM!!
              • 5459
              Yes its easy to remove. The TCR sensor that is showing 0.00% is on the developer unit. But with a new machine i would reseat all the connectors on the OACB and the relay board below the units.
              The TCR ratio is independent of the HV control board and with small amount of prints, i would guess it would be a connector or a board.
              The TCR sensor itself is not like the old ones it's a non-contact type, it's a coil printed on the circuit board and not much that can go wrong with it.
              Whatever
              • freixi
                • May 2009
                • 53
                Thank you for the quick help ,
                we are in contact with Konica Minolta for the change of the machine since that is new and has very little copies .
                Should it not work I'll do all thanks to your help what has been proposed and report what was it.
                Many Thx
                Freixi
                • freixi
                  • May 2009
                  • 53
                  Hi Guys.
                  After I installed a new developer, the problem not solved.
                  I then expanded the subhopper and found that the small cabel for steppermotor black was very loose. , Have it re-connected and tested. it works again.
                  Control its simples. Remove the Tray from top and see the tonner bottles.. Reconect the harnes from stepper motor M6.
                  see atachment..
                  Good luck and many thx to all.
                  Freixi
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    A factory mistake hey ?
                    We've NEVER seen that on a konica before
                    • allan
                      RTFM!!
                      • 5459
                      Sure you removed the orange thing from the K drum?
                      Whatever
                      • JR2ALTA
                        • Feb 2010
                        • 2028
                        Great follow up and pictures!
                        • freixi
                          • May 2009
                          • 53
                          • allan
                            RTFM!!
                            • 5459
                            Its a stupid question.
                            Its part of the packaging.
                            Whatever
                              • 22954
                              Did you miss the resolution Allan? He found a couple loose connectors to the hopper motor. There are even pictures. =^..^=
