df 621 doc feeder problem (fits bizhub 423)
  • brent
    • Nov 2008
    • 1214
    there is no code on the machine. but everytime I feed a document the cleaning system will try to rotate. and makes a noise.
    so I am calling in an expert (you guys)
    if it is not that bar that cleans the slit glass there is something else going on up there.. any thoughts?
    bizhub 423 doc feeder df 621
    any help will be appreciated
    brent
  • allan
    RTFM!!
    • 5462
    Re: df 621 doc feeder problem (fits bizhub 423)
    Does it feed the paper or does it just sit there?
    Whatever
      • 15068
      Have you taken the front DF cover off to see if the slit glass cleaning motor is actually turning?
      I'm pretty sure you can turn the cleaner off in service mode.
      • allan
        RTFM!!
        • 5462
        Are you getting a D-code?
        Whatever
        • SmellsHot
          Head Tech
          • 512
          Check to see if the white mylar is hung up on the opposite of the cleaning brush. You can turn it off, but it still rotates once before every job....pretty stupid if you ask me. Otherwise it rotates after every sheet......
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • brent
            • Nov 2008
            • 1214
            yes it works just fine. It's just wearing out because it rotates so often I wil look but I do not think the white Mylar is in the way. Thanks
            brent
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              I had one giving me issues with that cleaning roller. I cut the belt off. Never had another issue. The 250/350 got along well without it.
              • brent
                • Nov 2008
                • 1214
                I will head back out there in a day or two.. I thought about the belt deal. are you sure it wont trip a code by not timing the roller for turning?
                that is pretty ingenious.. I just don't think you can turn it off completely.. but I would in a heartbeat if I could
                brent
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  brent
                  No code, works great. Cut that bitch if you can't fix it, or just remove it.
