C5501
  • CrapAimer
    • 296
    C5501
    Hi All
    Just got a C5501 in, can anyone advice as to the best print driver to use so i can download it.
    Regards
    George
  • allan
    RTFM!!
    • 5462
    Re: C5501
    There is an IC408 and an IC305 option for the machine so it depends on the hardware on the machine.
    Whatever
    • CrapAimer
      • 296
      Re: C5501
      it has a fiery X3ety2 if this helps
      • Moza
        • 232
        Re: C5501
        Not realy.......is it a stand alone fiery or small one bolted to the back ?
        IC-408 is the embedded
        IC-305 is stand alone
        • Albonline
          • Sep 2008
          • 1151
          Re: C5501
          x3ety is 408
          • CrapAimer
            • 296
            Re: C5501
            its the small one bolted on the back
            • Moza
              • 232
              Re: C5501
              All the print drivers are on the Fiery already. If its connected to a network or you connect your laptop directly you can either find them in PC_User_SW folder or you can browse for the printers installed and just click on the print queue and it will install the driver for you.
