!R! SEM6; EXIT
  • uzicomp
    • Feb 2015
    • 35
    !R! SEM6; EXIT
    Hi
    I have a copier 283
    Each time a customer sends over the Internet Print
    He gets the page with this caption
    ! R! SEM6; EXIT
    And then the print goes
    Does anyone have an idea or solution to the problem
    In the office no problem printing
    Thank assistants
  • emujo
    • Jun 2009
    • 3009
    Re: !R! SEM6; EXIT
    If you are having issues printing web pages you can try a few things...Try a different browser, try downloading and saving the images in a PDF format, then sending the job, or, in the driver preferences, try changing the original type under quality to "Web"...If that doesn't help you may have to get a tech involved to update the MFP firmware and obtain the latest drivers. If the print driver does not understand the image it will error out. I will confess that I have never seen that particular error message though. Emujo
    • uzicomp
      • Feb 2015
      • 35
      Re: !R! SEM6; EXIT
      ty I will try it
      • logrady2331
        • Feb 2011
        • 301
        Re: !R! SEM6; EXIT
        Seems weird but that string looks exactly like a Kyocera Prescribe command. Odd.
        • uzicomp
          • Feb 2015
          • 35
          Re: !R! SEM6; EXIT
          What it means?
          • emujo
            • Jun 2009
            • 3009
            Re: !R! SEM6; EXIT
            Google search shows that this is a Kyocera error meaning you have the wrong driver installed...Are you using a Kyocera driver to print to the 283? If so then you are beyond our help in this forum....Emujo
            • uzicomp
              • Feb 2015
              • 35
              Re: !R! SEM6; EXIT
              of course not
              • CompyTech
                Super Tech
                • Feb 2011
                • 706
                Re: !R! SEM6; EXIT
                Originally posted by uzicomp
                of course not
                Just because the name in the printers and devices window says Konica Minolta does Not mean that the driver is Konica Minolta. In other words, the name of the printer can be different than the actual driver installed in the computer. Usually IT will load random drivers and give printers random names. I would delete and reinstall the correct driver, make sure it's PCL. Good Luck!
                • uzicomp
                  • Feb 2015
                  • 35
                  Re: !R! SEM6; EXIT
                  ty
                  I am going to di it
                    • 22996
                    Re: !R! SEM6; EXIT
                    You are exactly correct. The PreScribe code listed in the title is the first line of data sent by a Kyocera print driver to specify PCLXL print language. Only a Kyocera printer can read that data. What you need is the appropriate print driver installed, and this one removed.
                    We had a customer that had 60 or so Kyoceras, and was trying out a few Konica Minoltas on demo. The complainted that they were getting this page on every print, and sometimes PostScript error prints of 400 to 500 pages, one line per page. They were adamant that the Kyocera print driver should work on every brand of printer. =^..^=
                    • uzicomp
                      • Feb 2015
                      • 35
                      Re: !R! SEM6; EXIT
                      Thank you all
                      The problem was due to a customer's driver Kyocera connected
                      I installed it appropriate driver and the problem disappeared
                        • 22996
                        Re: !R! SEM6; EXIT
                        Congratulations. =^..^=
