Bizhub C 253 Scan/Fax Button not working
  • augustinermonch
    • Jul 2025
    [Misc] Bizhub C 253 Scan/Fax Button not working
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Bizhub C 253 Scan/Fax Button not working
    check the HDD is turned on and operational.
    without it these functions are impossible
    • augustinermonch
      Hello,
      how i can check the HDD ?
      Is the Machine Working without an HDD ?
      How to install an HDD ?
      THANK YOU
      • Tech Helpdesk
        • Jul 2015
        • 112
        Originally posted by augustinermonch
        Hello,
        THANK YOU
        [ATTACH=CONFIG]30053[/ATTACH]
        Has the fax option been attached to the machine ??
        • emujo
          • Jun 2009
          • 3009
          With or without a fax, the scan/fax button should respond...Print out the network config sheet, the HDD should be listed as installed. The HDD must also be formatted correctly. These MFPs came with HDDs but some companies remove them for security concerns before reselling them. Emujo
          • augustinermonch
              • 14756
              To see if it is physically installed, remove the left rear plastic cover and the metal cover behind it. The HDD should be there.
              To see if it is electronically installed, go into service mode-system 2-HDD-installed.
              Once installed do a logical format.
              • augustinermonch
                  • 23008
                  So look at System2 > Option Board Set > HDD ... if it's set to Unset, just change it to Set. You may need to reload the video files. =^..^=
