BHC6500 sc code c4721 APC fail
  • Desert Rat
    • May 2008
    • 1089
    I called Hytec on this, their tech said it is referring to the black laser unit.
    I pulled the black laser thinking it over heated. But no it codes out
    with in a minute of power on.
    I reseated the connectors a couple of times and dusted off the laser unit.
    The lasers for the colors are also dusty but working.
    Hytec said it is either the laser or the Image Processing bd.
    I need to know what others have done to fix this problem.
    And how much trouble it is to change the Image processing bd?
    DR
  • Tech Helpdesk
    • Jul 2015
    • 112
    Re: BHC6500 sc code c4721 APC fail
    Sounds like your black laser has gone down.
    • Desert Rat
      • May 2008
      • 1089
      Yes, I already know that. According to the book it is missing 12vdc from somewhere.
      Is that 12v always present at the laser connector even when it codes out?
      I am looking at diagrams today.
      Any know where I can get a black laser for this machine?
      DR
      • RAI
        • Feb 2014
        • 44
        It's usually not boards that fail. I've had a couple of bad color units I've replaced in the last few years.
        • Desert Rat
          • May 2008
          • 1089
          Rai,
          I'm hoping it's the laser.
          My customer is an indepedent quick printer. Notoriously frugal.
          He may not want to purchase the laser just to see if that's the problem.
          If it is the board I may have a problem with the price or the installation
          Stuck between a rock and a hard place again. Damn
          DR
          • Desert Rat
            • May 2008
            • 1089
            My customer bought a black laser unit and today I installed it. The C4721 code has not re-appeared.
            Instead it gave me a C4520 clr registration error.
            I went into service to run the auto clr regist. program and it coded out with C4503.
            Power cycle to clear code and try again, next code was C4502. Cycle the power and give it
            another shot got a code C4501.
            These last three code all read the same except they refer to the color lasers.
            Defined-- when laser correction motor on laser correction sensor was turned off.
            Pulled all the lasers out and clean the very dusty laser cavity. Try again and it is stuck on
            C4501 for the yellow laser.
            The choices the trouble shooting gives me is PRCB, laser motor or sensor.
            Now what? I'm thinking the PRCB may have to be replaced.
            How much trouble is that going to be for an indy without firmware?
            This board is serialized correct?
            Any suggestions?
            DR
            • Desert Rat
              • May 2008
              • 1089
              Had to try it again now it giving me the C4503 code Cyan laser motor or sensor???
              Tried to recall standard data at the factory level and no go.
              still C4503 when running the auto clr regist. program
              and C4520 in copy mode.
              DR
              • Desert Rat
                • May 2008
                • 1089
                This problem has got my head spinning. Here's what I've done: Customer bought a black laser and I installed it. The SC4721 has not come back
                sense. I did the LD bias adjustment in the book, ran auto gamma, drum potential sensor and then auto clr registration. Back to the 4503,02,01 codes.
                Ran the manual clr registration. It gave me an ERROR 1 chart not detected. Ran the recall scanner standard data to the factory level.
                Also ran recall standard data for the printer to the factory level.
                Ran test prints #11 beam check, the color in the squares did not look right. It looked dark.
                #53 overall half tone at density 70 and 255 looked ok.
                #80 print characteristic evaluation, this print actually looks good no sign of mis-registration color wise. And it looked square on the 17" page.
                #54 gradation evaluation pattern, the colors on the lower half of a 17" print looked very lite and faded. And the yellow bar was half off the
                page. There was a larger margin on the left side.
                I adjusted the printer gamma sensor offset and that brought the lower half of #54 up but still the yellow is half off the page.
                Now when I run the manual clr registration adjust it gives an ERROR 5. And some of the readings had N/G next to them.
                I will work on posting the samples and I may have a screen shot of the ERROR 5.
                This machine needs a tune up. The drums are at 200% plus, the developers are at 115% plus and the transfer belt looks worn. There is a piece
                along the front edge that is loose. This piece is 3-4 inches long. And the belt is about to track over the gear in the front.
                The customer, because of test print #80 has a hard time believing the transfer belt is at fault. I kinda do too.
                It registers the cmy to the black. How can I get the black back to where it should be?
                I wonder if I slip a belt from an old C500 on the transfer assembly if that would work? I need to change something in there to
                strike a nerve. Come to think of it, after it errors out with the 4503,02,01 codes I do not remember seeing the hash marks it
                creates for the adjustment. If the colors key off the black laser and its off by an inch and half, then the sensors would not see
                the marks. I will make a point to look for the hash marks next trip out.
                I did remove the sensor assemble from the left side and cleaned all the sensors, even under the
                lens for the Registrations sensors. And replaced one of the shutter springs.
                I try to be through, did I miss something right in front of me.
                DR
                • Desert Rat
                  • May 2008
                  • 1089
                  Here are some samples. I will see this machine today.
                  20150821_182100.jpg20150821_181921.jpg20150821_182138.jpg20150820_001648.jpg20150821_182009.jpgHere are some samples. Let me know what you think.
                  DR
                  • tulintron
                    • Jul 2014
                    • 669
                    [ATTACH=CONFIG]30368[/ATTACH][ATTACH=CONFIG]30369[/ATTACH][ATTACH=CONFIG]30370[/ATTACH][ATTACH=CONFIG]30371[/ATTACH][ATTACH=CONFIG]30372[/ATTACH]Here are some samples. Let me know what you think.
                    DR
                    you believe would be the belt?
                    I try to calibrate sensors registration PS8 and PS9.
                    I believe that this error linked the exchange laser.
                    perform whole procedure again.
                    Performed recall standard data in Printer Adjustment?
                    • tulintron
                      • Jul 2014
                      • 669
                      performed in 46-00 i / o check before replaced?
                      what outcome?
                      • Albonline
                        • Sep 2008
                        • 1144
                        DR
                        i have had the adjusting motor hang up on unit that have been out of the copier, flip the unit over and look.
                        • Desert Rat
                          • May 2008
                          • 1089
                          tulintron, I re-entered the info from the labels on all lasers and re ran the LD bias adjust.
                          The 46-00 output program ran fine. No codes til I tried to run the auto clr regist adj. That gave me
                          a 4502 code. Manual regist adjust gave me an error 1 turn the print around and get an error 13.
                          Normal copy mode error is 4520.
                          My customer is stuck on that #80 print saying the quality is fine.
                          Albonline, I pulled the black laser out to check the motor. All I saw was a cable and spring with a metal piece that
                          has two holes for the sensor. When it stops during the auto color regist all I see are a cyan and magenta line
                          across the belt. Thats it.
                          DR
                          • Desert Rat
                            • May 2008
                            • 1089
                            It has been suggested that I upgrade the firmware. I believe it has V50.
                            I am looking for v60 or v70, if anyone can help.
                            DR
                            • Desert Rat
                              • May 2008
                              • 1089
                              Still looking.
