Screen tuch problem with konical minolta bizhub c451
  • techmayor92
    • May 2015
    • 18
    Please can anyone help out on this issue? I have a konical minolta bizhub c451 tuch screen problem have change the screen still have same problem please tech help me out am also a technician I will be glad to hear from my great tech Thanks God bless
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Screen tuch problem with konical minolta bizhub c451
    sometimes I think people lie and say the replaced the obvious part in hopes we provide some miracle *free* solution.
    • Hansoon
      • Sep 2007
      • 3391
      .... or they leave the crud between the "new" (hopefully) screen and the operation panel......, or what I have seen too, they put the screen backwards in and also; happened several times, they forgot to remove the protecting foil of the new screen......
      Don't laugh, I have seen this more than once. A tech claiming that a new touch panel we provided to him is not working. When inspecting the part, I found the thin protecting foil still untouched in place. Happens mostly with touch panels for KyoceraMita. Also happening often with the thin KyoceraMita panels is that they are returned because of a crack. Customer claims that it came already cracked in the packing. This does not explain the fact that in these cases the foils where removed and put back in place and especially why on the contacts of the ribbon cable there are already markings of a board connector......
      Hans
      • techmayor92
        • May 2015
        • 18
        It one of my friend give dat screen please can printer board curse touch problem or the tonner chip curse the client told me he refill the tonner and e did not change the chip please people help me out
        • techno77
          • Jul 2014
          • 7
          Try replacing the memory.
          • femaster
            • May 2011
            • 1514
            Or swap the location of the 2 sticks. If the copier fails to boot after that, then you have at least on bad stick of RAM.
