Bizhub 350 Phantom Jam Tray 1
  • richmods
    • Aug 2013
    • 91
    I have an old bizhub 350 with 225K on it that jams in tray 1. I should clarify that the paper never leaves the tray. Tray 2 works fine. I started by replacing separation roller, feed wheels, and both one way bearings. That didn't help so I then replaced the pickup clutch assembly (I think that's what is called) on the back wall and that didn't help either. The elevator motor works fine. The only thing I can find in the service manual suggest it could be the sync roller sensor or the vert transport sensor. Any advice would be appreciated. Thanks
  • ck1
    • 485
    Re: Bizhub 350 Phantom Jam Tray 1
    Did you try change the small clutch at feed roller ? try it
    • copyman
      Owner / Technician
      • Sep 2005
      • 4627
      Do you have the closure mod installed for tray 1? On right side of paper tray is a white piece that hold paper tray closed. The new style is black with a spring.
      Also on top of paper tray there is a small square that contacts paper feed roller pressure arm, if you build this up about 1/4" it will put more pressure on pick up roller. I use a double sided tape, etc to build up.
      Hope this helps.
      • allan
        RTFM!!
        • 5462
        There is a lever on the feed unit that drops the pickup tyres if the tray is closed.
        That lever can break off. To test if its the tray that's not closing press the tray in by hand and see what happens.
        Its also easy to forget the connectors on the clutch assy if it was removed.
        Whatever
          • 14520
          Also, check the paper tray where it latches to machine. It is likely cracked. There is a reinforce plate available from KonMin to fix this. I think the part# is 4030P00100
          • richmods
            • Aug 2013
            • 91
            Thanks all for your input. I have tried most of your suggestions but copier addict may be onto something here. Heading back there tomorrow to investigate further.
            • fixthecopier
              ALIEN OVERLORD
              • 4714
              Every bizhub we had broke the top and sometimes the second tray. Remove the front piece that has the handles. The one right above the tray. This will give you a small crack in which you can see in the tray to see what is moving.
              • JR2ALTA
                • Feb 2010
                • 2030
                A bad registration clutch will not "jam" per se. But it will give you frequent false "Add paper" messages which stops the copy process
                • ck1
                  • 485
                  You can try swap the full unit and see. ( my bh350 also got this issue after swap unit ok )
                  but one way clucth get this issue
