TA250CI
  • garyk
    • Jan 2007
    • 37
    TA250CI
    what happened to print density adjustment under Adjustment/Maintenance in Management Mode
    Firmware Version 2H7_2F00.012.012 2011.07.14 is this a firmware issue or something else?
    • 23008
    Re: TA250CI
    "print density adjustment under Adjustment/Maintenance?" Unless it appears under some other name, I have never seen this print density adjustment that you speak of, on any Kyocera. =^..^=
    • garyk
      • Jan 2007
      • 37
      Re: TA250CI
      on page 1-3-148 of service manual for kyocera TA 250CI shows this under Adjustment/Maintenance under pressing system menu key;also i just recently saw print adjustment on a km2560 in same place as above
        • 23008
        Re: TA250CI
        We must not have the same version of the manual. 1-3-148 of the Service Manual R7 describes U906 through U910 service modes.
        For System Menu > Adjustment/Maintenance you might take a look at the Operators Guide R12.23 pg 8-54, which does not have a print density adjustment. AFAIK, it never had.
        The only print density adjustment adjustment that I am aware of is a PreSribe command. For monochrome prints the default value is "3". To set print density to 4 (make the prints darker) send: !R! FRPO D4,4;EXIT;
        If the same adjustment is available for color prints, I'm not aware of it. =^..^=
          • 23008
          Re: TA250CI
          I did see the reference to print density adjustment on pg 1-3-164 of my SM, but in 7 years I have never seen it, and I have looked for it.
          Try the PreScribe command. =^..^=
