Kyocera FS-C8520mfp will not copy or print in color
  • ZeusGT
    • 271
    Hey guys,
    I have a customer with a Kyocera FS-C8520mfp that will not copy or print in color. The customer has replaced the transfer belt and toners, but it still will not copy in color. When you do a color registration test print, the print will print out in black and white only. When you print the supplies page, the color bars print out in black and white only. The error codes are 7620 and 7612 which is a cyan ID sensor error.
    Ive tried making sure full color is default and selected. I've tried resetting back to factory defaults. I've tried everything that I know of except to replace the PWB.
    Can an you guys please help with which way I should go with this? Oh and firmware is system 11.
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: Kyocera FS-C8520mfp will not copy or print in color
    System Menu>printer>change to color.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • B0265
      • Jan 2007
      • 718
      Try upgrading the FW. On versions earlier than v.06.12.0010 , when a color toner ran out the MFP switched to BW Printing but did not switch back to full color when the toner was replaced.
      • subaro
        • Oct 2010
        • 1274
        service mode number u089 , printing belt colours should show if the engine and drum/dev is functioning ok.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          take all the toner out, turn the machine off (complete off). reboot, after it says ready reinsert the toners. sometimes it likes to do this.
          Idling colour developers are not healthy developers.
