km 6030 code c0410
  • umer_ml
    • Sep 2012
    • 24
    km 6030 code c0410
    Hi I was routine cleaning of my dp km 6030,after clean my machine i face code c0410.i dont know what to do now ,i have clean and check dp main pwb with ctc and dry well but same result code appear and dp is not working,
  • subaro
    • Oct 2010
    • 1274
    Re: km 6030 code c0410
    remove the adf cable that connects at the rear of the machine and reinstall. routine cleaning should not cause any major problems, unless you were using liquids when the power was on.
    1087 1087 gets you to service mode. run u906 to do disable reset.
      • 23009
      subaro covered that quite nicely. You will need to do a Partial Reset to restore function. =^..^=
