Task Alfa 400ci - change warm up screen display
  • Reed
    • Feb 2011
    • 258
    I was wondering if someone could tell me how to change the warm up display on this machine. I picked up a used machine and it has the logo of another company on the warm up screen. When I went to class on this machine I remember the instructor briefly went over the procedure but I not longer remember how change it back or put my logo on there. Any help would be appreciated. Thanks!
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: Task Alfa 400ci - change warm up screen display
    if you have access to the class, you should have access to the manual no?
    u224 - Panel sheet extension
    Idling colour developers are not healthy developers.
      • 23010
      All you have to do is clear out the custom Splash file and the machine will return to the normal display. =^..^=
      • Reed
        • Feb 2011
        • 258
        thanks.. got it resolved. BTW.. Blackcat found an older thread where you told how to install the image. I ended up putting our company image on the warm up screen
