fs 1128 MFP sent fax has grainy background
  • RWP61
    • Sep 2014
    • 8
    [Misc] fs 1128 MFP sent fax has grainy background
    I have a customer with a fs 1128 mfp that has a grainy background only when sending fax out.
    Have updated firmware ran u600 and reinitialized the fax card
    Resolution is default at 200X100
    Attached sample portion of fax output.
  • walterman
    • 196
    Re: fs 1128 MFP sent fax has grainy background
    Is the fax line a Voip? Is it happening to every recipient or just one? Make sure the ECM is on in Sim 631; if, it is and your still experiencing problems, sim 631 reduce communication speed to V. 17(14400bps). If problem still exists sim U630 change tx to 500 and rx to500.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1869
      I would turn on confirmation pages to see what the machine thinks the faxed image looked like. That will narrow it down to a line or machine problem, since all other scanned functions seem to be good.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • RWP61
        • Sep 2014
        • 8
        Thank I will check the settings..
        • RWP61
          • Sep 2014
          • 8
          Thanks I will give it a try.
          • subaro
            • Oct 2010
            • 1274
            look at the original you are scanning closely. does it itself has background. sometimes the document printed has background and when faxing it amplifies the background.
            set the resolution to 200x200 and original to text only just to see if results are diffrent. if all fails, swap out fax pwb.
            • RWP61
              • Sep 2014
              • 8
              no back ground all on plain white paper. after further testing look to be a bad fax card.
              • allan
                RTFM!!
                • 5462
                Did you do as tmaged suggested, looking at the image on the confirmation report?
                Whatever
                • RWP61
                  • Sep 2014
                  • 8
                  yes have tried all above suggestions. And verified the line is not voip.
