Kyocera Taskalfa 180
  • Andrew Alphonsus
    • Sep 2015
    • 9
    [Error Code] Kyocera Taskalfa 180
    Dear Friends
    I am facing error code J10/J11 in Kyocera Taskalfa 180 digital copier. The paper was not picking from both paper cassette and Bypass tray. After replacing Main/Engine PWB copier has started to work again. Any other alternate measures to rectify this code.
    Alphonsus A
  • subaro
    • Oct 2010
    • 1274
    Re: Kyocera Taskalfa 180
    did you execute u906 from service mode? this resets machine disabled items. Should do this first before replacing boards. can't recall at the moment, but a similar model has the reset from the system menu and not service menu.
      • 23010
      Originally posted by Andrew Alphonsus
      Dear Friends
      Alphonsus A
      I don't understand the question. You fixed the machine but are unsatisfied with the solution? =^..^=
      • subaro
        • Oct 2010
        • 1274
        I think he wants to know if this happens again, what should be done or which part should be replaced or what steps to first check and take.
        My question, is why would the main and engine pwb both need to be replaced. If anything, the engine board alone should be replace.
        He did not say if he ran u906
        • Andrew Alphonsus
          • Sep 2015
          • 9
          Dear All
          I have entered service mode, used simulation20 and initialized all the data of the machine. Still error code was not going .This machine doesn't have a separate Engine PWB and so Main/Engine PWB has to be changed. My question is whether Main/Engine PWB can be repaired locally or any other solution in the PWB. The PWB is very costly and customers are bit unhappy.
          Alphonsus A
          • subaro
            • Oct 2010
            • 1274
            Dear All
            Alphonsus A
            You are correct, in that the engine and main are one board. I did not have the TA-180 manuals but was looking at the TA-181 which i thought would be similar. TA-180 is not available here. the 181 has separate engine and main board, same looks.
            These machines are old and the solution is to spend the money towards a new machine, or source another parts machine for cheap. customers has to be aware that nothing last forever and change is necessary when that time comes. just like my car, i want to keep it forever, but
