Windows 10 Usercodes Issue
  • ledoux
    • May 2009
    • 75
    I've seen this a few times now with some accounts that have jumped on the Windows 10 upgrade. If the driver is set to "Prompt for Account Code", Printing via Microsoft Office Suite or the Built in PDF Viewer, the code is not getting transmitted with the print job. You will get an account ID error. If you save the code in the driver everything works great. Has anybody else found a workaround for this? I've got a ticket open with tech support right now just wanted to see if anybody else has found a solution.
    So far Windows 10 hasn't been that bad for me just a few things here or there. I do get a chuckle out of it worked before I upgraded now the Printer is messed up!
    “Boring damned people. All over the earth. Propagating more boring damned people. What a horror show. The earth swarmed with them.” Buk
  • darry1322
    • Oct 2010
    • 817
    Re: Windows 10 Usercodes Issue
    Have you tried checking "print directly to device" in the advanced tab of the driver properties?
    • sdrawkcab
      Confused & Bewildered
      • Jun 2009
      • 317
      My understanding is that when a computer upgrades to Win 10, the installed TCP IP ports are changed to WSD ports. WSD ports don't support snmp, so the codes don't prompt, changing it back to TCP IP should fix the problem.
      Some days, it's just not worth chewing through the restraints
      • ZOOTECH
        Senior member of CRS
        • 3375
        HATE those WSD ports.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          Darry is correct, it's a known issue.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • darry1322
            • Oct 2010
            • 817
            I'll have to keep an eye out for this one.
            • ledoux
              • May 2009
              • 75
              That did it, thanks for the help!!
              • tmaged
                • Oct 2008
                • 1888
                Has anyone tested the KX driver that was released Friday to see if the issue was fixed ?
                When I talked with the hotline, they sad it should be fixed in the next release. I couldn't find anything in the notes regarding a fix though.
                Hope that helps !
                -Tony
                www.dtios.com
                • qbert69
                  • Mar 2013
                  • 1152
                  DAMN WSD TO HELL!!!
                  REACH FOR THE STARS!!!
                  Konica Minolta Planetariums!
                  • jmaister
                    certified scrub
                    • Aug 2010
                    • 755
                    Originally posted by qbert69
                    DAMN WSD TO HELL!!!
                    you could disable WSD printing, even Win 7 has been known to hunt for WSD printers.
                    Idling colour developers are not healthy developers.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      I don't think WSD was ever meant for today's intelligent printers and MFPs.
                      It may be OK for very basic desktop printers, but that's it.
                      I had an Equitrac install a few months ago where the customer's IT guy insisted on the WSD ports when he installed on the print server.
                      Had to change 14 print queues over to IP ports so that Equitrac would work.
                      • jmaister
                        certified scrub
                        • Aug 2010
                        • 755
                        I dont think WSD was ever meant to be intelligent.
                        HEYO~~
