Has anyone found a short cut for replacing those two rollers on the RADF2!! You know the ones that turn sticky.. I hope so, what a pain!
RADF 2
Re: RADF 2
No short cuts.
I keep rebuilt SRDF2's in the shop and just swap them out.
It is not a job I would want to do in the field. ( it would be nice not to include in contract since these are aging problems. the rollers I replace are all dry-rotted ).
I replace registration roller and lower conveying roller at the same time plus I do all feed rollers and check one way bearings.
It takes me a couple of hours or longer per doc feeder.
I have done 6 or so thus far and I do not see a fast way to replace them since so much is built around them.
If you figure something out that is faster, Please share...
Perhaps I will take pictures and share on next tear down. -
Re: RADF 2
No short cuts.
Perhaps I will take pictures and share on next tear down.Comment
Re: RADF 2
which are the two rollers you are referring. could you elaborate or give a part number ?
repaired quite a number of those in years gone by and don't recall having to replace rollers other than the pup,feed and sep . Yes, you have to clean the rest thoroughly as they get very dirty with black stuff buildup. the job is not difficult, just a little bit of work to get to the separation roller. and you have to clean and lube the one way bearings and the brass bushings.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Re: RADF 2
Could you mean the Mita RADFII ... like from the 90's, on the DC-5585? Those machines should have been recycled a decade ago. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: RADF 2
I think he is referring to the kyocera falcon2 option SRADF2 doc feeder. This is a perfect case as someone trying to figure out what the poster really referring to. a simple inclusion of the exact model number would have eliminated blackcat wondering.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Re: RADF 2
I took a guess and thought it was a SRDF-2 which you see on Falcon 1's and 2's.
The rollers that dry rot, get sticky, and shrink are:
the registration roller (3BC08050) and
the lower conveying roller (3AL08112)
They are a royal pain to install. But we still have a few out and it is necessary to replace
when they get bad. They jam quite a bit at registration due to the rollers being smaller than
they should be. They get real soft and can fall off the shaft. you can stick your screwdriver right into them to the shaft when they are bad.
Here is a bad photo I took a while back. New roller next to old roller.
I have another one to do soon, so if you want photos - I might post.Attached FilesComment
Re: RADF 2
Is this like the neoprene rollers on the Canon RDFI and RDFII that turn into black chewing gum? You can avoid having this happen, by using only water based cleaners like glass cleaner on neoprene rollers. Oil or petroleum based cleaners absorb into the neoprene and accelerate their degradation.
Whew! Remember those moving belt feeders? We had modified the hell out of them. Doubled up and weighted pickups, neoprene registration idlers, different white belts... even then they didn't feed very reliably. =^..^=If you'd like a serious answer to your request:
Re: RADF 2
I agree with Blackcat on cleaners.
Glass cleaner works very well.
I also think just a mixture of lanolin based hand soap and water does a good job.
No harsh cleaners as these may tack up the roller in the short run but will break it down over time.
The rollers in question in this thread will just break down naturally over the years.Comment
Re: RADF 2
Agree with the above, except most glass cleaner contains ammonia, which i don't like. There are general water base all purpose cleaners that work well to clean those rubber rollers. the lanolin base hand soap i have used and does an excellent job.
cleaning those adf rollers correctly is imperative to its longevity and usefull function. the feed,sep and pup are usually easily replaceable, but the other transport rollers if not cleaned properly with proper cleaners can cause undue trouble. This is the reason manufactures recommends using alcohol, as this evaporates quickly and does not harm electronics and is a relatively good cleaner. But alcohol is harsh on the hands and dries out the oils in your skin.
In my opinion water based cleaners is the way to go, but learn to use it properly. not saturate the rolles, but just the surface should be wetted with the product and agitated then clean with water and then dried with clean cloth.
There are lots of good biodegradeable cleaners out there, you have to experiment which one works for you.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Re: RADF 2
Agree with the above, except most glass cleaner contains ammonia, which i don't like. There are general water base all purpose cleaners that work well to clean those rubber rollers. ...
(1) gallon winter grade automotive washer solvent, unscented
(1) gallon vinegar windex
(1) quart cleaning vinegar
The reason for my aversion to ammonia goes back to my days cleaning floors at Kmart stores. My supervisor set me up with a chemical concoction to strip the wax off of an area. This lovely concoction contained equal parts ammonia and bleach, plus other things. After 2 hours I noticed that I was having difficulty breathing ... and the pattern had melted of my new Converse All Stars. It was nearly a week before my breathing returned to normal, and just a whiff of ammonia affects me strongly. I won't stay in the same room with any amount of ammonia.
