fs1018 scan to email error
  • freccia
    • Aug 2008
    • 13
    Hi, I have a problem with this kyoceramita fs1018 scan to email. If gives me error 3101, meaning authentication error, although I am trying to use the same mail account as that of the client, and also using authentication, login and name and password? Any help.
  • anthony123
    • 62
    Hello, Has it ever worked? run ipconfig /all .....and make sure your dns server is programmed into the machine correctly also your ip address and subnet. Can you print? If the sever requires auth are the settings the same? recheck pop and smtp settings. recheck all settings from a networked pc and make sure they are the same .......RB
    • freccia
      • Aug 2008
      • 13
      Yes, it works as a copier, network printing on mac and windows xp, but not scanning to email. dns all ok, gateway ok. It used to scan to email when it was at another site, but this client has moved and has a new server and network.
      • mckinley
        Chief Twiddler
        • Dec 2006
        • 150
        i work on toshiba's but from experience on them, usually if scan to email won't work a couple of things need to be correct, 1st is the primary & secondary wins servers, if they have moved and are on a different server maybe they are using different wins servers. 2nd is their firewall, you may need the ip/mac setting as allowed for smtp communication.
        can you scan to file? if you can the wins are probably ok, if not thats another sign that they are set incorrect.
        Happiness Is The Road.
        • freccia
          • Aug 2008
          • 13
          Ok, will check wins server cos usually we do not input these. Also cannot scan to folder cos since they have mac dual boot, but client uses mac mostly. anyway will try to install on windows just to try out. Thanks for your help.
