DP-670B
  • cm79
    • 20
    DP-670B
    Hello all. We have a DP-670B that disables itself once a month. It works fine after i 906 the machine then about a month later it happens again. There is no jams or c-codes recorded on the unit when it happens. I've cleaned,blown out,reseated DP connectors and flashed the firmware .Has anyone ran into this problem before? Any help will be appreciated.
  • kjg
    • Mar 2009
    • 112
    Re: DP-670B
    It might be a good start to look at the Harness to the copier and Molex connector on the copier side.
    Harnesses over time do strange things and the Molex connectors can get loose or broken over time.
    Hope that helps a bit
    • cm79
      • 20
      Re: DP-670B
      I'll give those a try. Thank you.
        • 23008
        Re: DP-670B
        Are you sure about error codes? The only reason it should isolate is if it pulled an error code. Print off an Event Log. =^..^=
        • habik
          • 2013
          Re: DP-670B
          Lift the original tray guide and clean underneath.
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
