troubleshooting Kyocera kM3060
  • adel_nathan
    • Jul 2011
    • 103
    [Misc] troubleshooting Kyocera kM3060
    hi every body
    i was post my problem from 4 days ago
    about Kyocera KM3060 , when i power on , the machine hang and screen stopped at "PROGRAM LOADING"
    i notice that , if i unplug the power for 10 minutes or more , and plug again
    the machine open normally , after some jobs it hanging again
    i try to upgrade soft ware , but i fail
    i change : 1- ram , 2- Dimm and 3-hard disk drive
    from another machine working good
    but nothing help
    please any advice will be appreciate
    thanks
  • adel_nathan
    • Jul 2011
    • 103
    Re: troubleshooting Kyocera kM3060
    please , please
    help
      • 23010
      Originally posted by adel_nathan
      hi every body
      but nothing help
      thanks
      When you say DIMM, do you mean memory DIMM or CODE DIMM? The memory DIMM is for short term handling of the print data. The CODE DIMM holds the firmware. I would have changed in this order:
      Main PCB CODE DIMM
      Operation Panel
      Main PCB
      ... each with a firmware upgrade.
      • subaro
        • Oct 2010
        • 1274
        what happen when the upgrade fail, was there an error message ?. Is the machine plugged into a separate power outlet or sharing the power with other machines?
        did you update with the method in your previous post that someone there outlined to you. unplug the hard drive and boot the machine, it should code out or is
        the message the same.? when upgrading the firmware, it can take quite a bit of time sometimes, so leave it for a while and do not uplug it prematurely. and as the previous guy, i believe Darryl menitoned, you may have to try it more than once also as he said.
        [make sure the hard drive is connected when updating the firmware]
        • adel_nathan
          • Jul 2011
          • 103
          Main PCB CODE DIMM
          Operation Panel
          Main PCB
          i change DIMM which in back plug into Main PCB
          i don't know if there are another one !!!! where it ????
          • adel_nathan
            • Jul 2011
            • 103
            when i try upgrade , i switch off M/C and attached USB which have a firmware
            turn M/C on
            after a while the screen gives "PROGRAM LOADING " and disappear after little the black screen come\
            and the memory led flashing
            nothing on the screen shown the process progress
            am waiting for 35 minutes
            turn off M/C
            and the software not upgrade
            do i make mistake ????
            • subaro
              • Oct 2010
              • 1274
              In your previous post about this same problem. did not a guy mentioned how to update the firmware. here is his post. by darry1322. read carefully and understand the procedure.
              Re: kyocera KM 3060
              In my experience, 9 times out of 10 :
              put latest firmware on a 4 gig or less thumb drive
              take the lower cover off of the panel.
              with a flashlight and good eyes, look for the small ( very small ) switch on the edge of the panel board.
              toggle this switch ( with power off ).[ toggle= move switch to other position]
              turn the power on and wait until the memory light stops flashing.
              power off and toggle switch to the starting position.
              insert thumb drive into the panel and turn the power back on.
              find something to do for the next 7 minutes until the panel starts loading firmware.
              after the firmware is finished your panel should respond again.
              It may take more than 1 try to get this to work.
              the panel he is referring to is the lower control panel or operation panel, just below the screen.
              When you do it the way you are doing it and the screen is blank, leave it at least for 2 hours. If does not work, then do the above. your choice.
              • Lijodamodaran
                service manager
                • Sep 2014
                • 56
                Facing same issue on km2560 .I dont have firmware for it.please help me sir
                Sent from my LG-P715 using Tapatalk
                • wholesaler
                  • Jun 2015
                  • 20
                  [QUOTE=adel_nathan;495468]hi every body
                  but nothing help
                  thanks[/QUOTE
                  it sounds like a hard drive issue
                  • Santander
                    • May 2009
                    • 768
                    follow Subaro's instructions above. If you did not wait for the memory LED to stop flashing you have now corrupted the firmware and using a usb drive will not work. You need to upload the firmware via a CF [compact flash card] plugged into the back of the machine. You should also update the firmware twice per the tech bulletin to make sure you have overwritten any bad sectors in the memory. Just had this happen today where the first tech got impatient and powered down the unit before the upgrade completed and could not finish the firmware update, the display just stayed on Program Loading forever! Using the CF would also hold true if you are upgrading from an older F/W level. Be patient, the upgrade today took 15 minutes before the display changed from program loading to updating firmware using the CF.
