FS-C8520 F25E code
  • nathicana
    • Aug 2008
    • 335
    FS-C8520 F25E code
    This FS-C8520 Kyocera MFP is throwing F25E codes. Customer says it is usually first thing in the morning. This machine has a history of F000 codes (communication between main board and operation panel). We have replaced the main board and updated firmware after talking to Kyocera about the F000 codes. When I called them about the F25E codes, they said it is a problem in the network management section which is on the NIC (main board). We are reluctant to replace another main board since it was replaced less than a month ago for the F000 codes. Has anyone experienced the F25E code?
    • 23010
    Re: FS-C8520 F25E code
    CF25E is a Network Manager error. My references tend to blame firmware, but I think that I'd take a different approach.
    I think I would disconnect from the network to see the the code re-occurs. Also I'd connect to my laptop and print/scan/etc. If I still did not get any CF25E codes, I would put it back on the customers network and see how long it takes for the code to come back. =^..^=
