KM 5500i
  • kmtech
    • Sep 2008
    • 125
    #16
    Re: KM 5500i
    Originally posted by wragsdale
    I don't think there is a size limit for the USB drive, but to be safe you may want to use one under 8GB.
    Also, I was wrong about the red marking. It's actually an "R" on the top right corner of the EEPROM. As seen here: http://puu.sh/lvbfz/34503f93bf.jpg
    Thanks a great deal.. I will check tomorrow, and get back at ya.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1896
      #17
      Re: KM 5500i
      Also, you're not backing anything up to USB. You're loading special firmware on which adds U026. This code allows you to back up the eeprom to the HDD, then restore it to the new eeprom.
      Load special firmware. Reboot machine & run 026 backup. Install new chip & power on, then restore in u026. Power off then reload full firmware.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • kmtech
        • Sep 2008
        • 125
        #18
        Re: KM 5500i
        I read that but it just would not run the backup firmware, I going to get a smaller usb, the one i used was 80gig. like i said earlier i tried to install the backup firmware and for all the listed files on the copier screen it said no change.. just for the hell i looked for Sim 026, it was not active. so i will check it out to see if maybe because it already has the chip installed it wont run again.....Thanks again...
        • tmaged
          • Oct 2008
          • 1896
          #19
          Re: KM 5500i
          Make sure you've got the correct special firmware for that model. There are different ones for the color boxes. I would think of it was the USB drive, it would just boot normal as if it couldn't read it.
          Hope that helps !
          -Tony
          www.dtios.com
          • kmtech
            • Sep 2008
            • 125
            #20
            Re: KM 5500i
            Thanks to all of you that contributed, I check the chip, it was old. so i went to walmart got a 8 gigger and what do you know it worked.. thanks a great deal for all the effort..
            Bill
