Print quality
  • dirham
    • Nov 2011
    • 8
    Print quality
    Hello....... I just new in this brand.
    I have trouble print quality in Kyocera Km 4050. The toner to low. I need help how to up the toner level... thanks before..
  • jhalfhide
    • Apr 2015
    • 454
    Re: Print quality
    If you mean the prints are too faint, you need to do a developer refresh to start with. This is maintenance mode item 130.
    • darry1322
      • Oct 2010
      • 817
      Re: Print quality
      Are you sure it's low toner? You could have a problem with the transfer roller if you have light copies and prints.
        • 23008
        Re: Print quality
        What happened to your previous post?
        My answer remains the same. The KM-4050 is a moncomponent developing MFP. Toner density is not an issue. Either you have toner or you don't.
        If you have some sort of an image quality issue, you might post a scan or photo of the image quality problem. =^..^=
        • jhalfhide
          • Apr 2015
          • 454
          Re: Print quality
          I know right... Low toner... Put one in [emoji23]
