Hi guys,
could do do with a little help on this one.
Basically I've a Taskalfa 250ci that is jamming everytime, jam31 when feeding from cassette 1 and jam18 from cassette 2. With the jam31, the Regist actuator is okay, the sensor is okay, the clutch tested okay but replaced it anyway to be on the safe side, the gears on the feed assembly look fine and move without resistance. Am I looking at the feed board here or is there something I may be overlooking? (Just before I go the costly route)
As for the the jam18 in the second cassette could these two jam codes be linked? And again could the feed board solve both problems, because all sensors and clutches are testing fine from maintenace mode also. Firmware on this machine is up to date.
also if it helps it feeds okay from the mp tray. Any help appreciated.
