FS-c2126 Quality Issue
  • monstott2010
    • May 2025
    I know I have seen this before, but for some reason, cannot remember what I did to fix... Attached sample. Color calibration cycle leaving strips on the first copy out, 2nd page and on seem ok, until the next calibration or pwr cycle then issue returns.. have reloaded firmware and have tried a different transfer belt. This was started by another tech so not sure what all has been tried.2126.pdf
    • 22930
    Re: FS-c2126 Quality Issue
    You're seeing the color registration patches on the belt. It's a primary belt cleaning fault.
    I know you say you swapped in a different transfer belt ... but it couldn't really be anything else. Perhaps the belt unit you installed isn't any better than the first. Usually you have some nice self adhesive labels stuck in the belt cleaner unit. =^..^=
    • monstott2010
      Thanks Blackcat, I new I could count on a response from you :-) I was certain it was the belt cleaning unit, that's why I was really shocked when the second belt did the same thing... checked grounds too, thought maybe an issue there... haven't found anything that makes sense...
      • subaro
        • Oct 2010
        • 1273
        Step 2, Checking the Auto Color Registration
        Check whether the Auto Color Registration is executed normally following the procedures below.
        If it is not executed normally, the Intermediate Transfer Belt may deteriorate over time. If the Transfer Belt is found to be
        deteriorated, replace the Intermediate Transfer Unit.
        Check of the Auto Color Registration
        1. Turn the Main Switch ON and wait until the machine comes to ready.
        2. Turn the Main Switch OFF, and open the rear cover.
        3. Cheat the inter-lock switch at the rear left side of the machine by using a flat-blade screwdriver. (Fig.25)
        4. Turn the Main Switch ON. (The machine drive starts.)
        5. Determine whether the Auto Color Registration has been normally executed. (Fig.26, 27).
        [Normal] The Color Registration patches appear at both sides of the Transfer Belt, one time, and then the machine
        drive stops.
        [Failure] The Color Registration patches appear at both sides of the Transfer Belt, one time, disappears and appears
        a second time, and then the machine drive stops. Replace the Intermediate Transfer Unit if this occurs.
        The above is from kyocera bulletin on quality issue. two screws and remove the transfer belt cleaning assy. remove cleaning blade and vacum the brush inside.
        reinstall and check again.
        • monstott2010
          Ok, never mind... I found the problem... the drive belt from the motor to the clean section drive was apparently pinched/not moving properly... freed up and working fine now... I knew as soon as I posted for help I would find something simple....
            • 22930
            Excellent. Good catch. =^..^=
