I'm having trouble updating the firmware on this model. tried 4 or 5 different thumb drives all formatted to fat or fat32 makes no difference, tried older firmware also tried thru net-viewer and it fails, tried the combined pack also, never goes to the update screen, tried printing from the same thumb drives thru the usb port and it work fine...anyone see this before, the thumb drives light up so they are recogniz000ed
fs-c2626
Re: fs-c2626
Format the usb drive in your computer. make sure the extracted firmware files are on the root of the usb drive. If it does not go to the updated screen, it is either the incorrect f/w or the files are on a folder and not the root of the usb drive. unpack the dowloaded files to a folder in your computer and then copy[all the files and not the folder] to the usb drive, and see if all the files are copied. have done hundreds or these and if any failure, was due you my error in some way. I use a 512mb usb which is more than sufficient.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burke -
Re: fs-c2626
Format the usb drive in your computer. make sure the extracted firmware files are on the root of the usb drive. If it does not go to the updated screen, it is either the incorrect f/w or the files are on a folder and not the root of the usb drive. unpack the dowloaded files to a folder in your computer and then copy[all the files and not the folder] to the usb drive, and see if all the files are copied. have done hundreds or these and if any failure, was due you my error in some way. I use a 512mb usb which is more than sufficient.If you'd like a serious answer to your request:
