KYOCERA M2030DN
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] KYOCERA M2030DN
    Hello ..we have error code C2000 in KYOCERA M2030DN ..l controlled all parts ...this machine is news .....any idea ?
    BEST TECHNICIAN . NICE PEOPLE .
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1256
    Re: KYOCERA M2030DN
    Error code C2000 is main motor not turning properly. Something is tight or not spinning freely loading down the drive motor. Check each component one by one ie: fuser/dv units/drums to see if they are binding.
    • daveh12
      • Jul 2012
      • 157
      Re: KYOCERA M2030DN
      I've seen fusers seize up on this model long before they should. No option but to replace.
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        Re: KYOCERA M2030DN
        hello again ..l try controlled all parts of this mfp ..all is good ...fuser parts ..develop parts ...toner parts ...laser parts ...also l enter simulation ( U21 ) but unfortunate any solution ..pls any idea !
        • taskalfaman
          • Nov 2009
          • 137
          Re: KYOCERA M2030DN
          hi,
          check the drum contact on the right side.
          do you hear a strange noise?
          if yes, check visually and you will mostlikely see that the contact mass of the drum if not in proper position.
          bent the contact and the machine will work properly.
          please feedback.
          • Kyo fan
            • Dec 2013
            • 368
            Re: KYOCERA M2030DN
            Pull the drum unit out and turn it by hand (press the gear on the right down), it must go smooth. Do the same for developer unit. If both are turning properly, than the right side has some mechanical factory problems (assuming the machine is new as you said). It could be the main motor or some of the gears around it.
