Hi All,
I have a taskalfa 2551ci that has error code C2560 Conveying motor 1 startup error.
so far I have replaced the engine pwb, CM1 (Motor) and checked the cable and still ng.
If I meter the cable I get all the correct readings for 24v, start sig etc and the cable passes a continuity test.
I have also tried main pwb.
I have a feeling that the error code is a red herring but cannot locate a cause.
Any help appreciated.
Regards
Regards
