TaskAlfa 2551ci
  • lanierboy
    • 149
    [Error Code] TaskAlfa 2551ci
    Hi All,
    I have a taskalfa 2551ci that has error code C2560 Conveying motor 1 startup error.
    so far I have replaced the engine pwb, CM1 (Motor) and checked the cable and still ng.
    If I meter the cable I get all the correct readings for 24v, start sig etc and the cable passes a continuity test.
    I have also tried main pwb.
    I have a feeling that the error code is a red herring but cannot locate a cause.
    Any help appreciated.
    Regards
  • copydocinc
    • Mar 2015
    • 263
    Re: TaskAlfa 2551ci
    I think you'll need to check all the gears and rollers that are turned by that motor and find the one that is binding up and not letting the motor turn freely.
    • lanierboy
      • 149
      Re: TaskAlfa 2551ci
      Thank you but as part of my test i removed the motor from the drive assy and held it in my hand while starting the machine and the motor did not try to turn,
      • Munny_91
        Re: TaskAlfa 2551ci
        Originally posted by lanierboy
        Hi All,
        Regards
        I have stumbled on this issue today. Just for future reference I found it to be the transfer belt had been clogged up with toner. Causing the waste toner pipe to be clogged up also causing the transfer belt hard to rotate when in machine. You can vac out transfer belt. But I recommend just replacing the toner waste pipe. This should sort it.
