kyocera KM C 2525
  • raztech
    • Dec 2008
    • 88
    kyocera KM C 2525
    Hello dear
    i couldn't active scan for the copier color laser KYOCERA KM2525..( a red flag appears on the left keyboard) ( i think scan is desactiveted) ..
    how can do it works please..
    many thanks
  • XaR0uLiS
    • Jul 2014
    • 23
    Re: kyocera KM C 2525
    Originally posted by raztech
    Hello dear
    many thanks
    Hi,
    if you press the Scanner button what do you see on the display?
    You can check if there is the option Scan Default in the System Menu.
    Check the network cable. You can use the utp from printer to test the scanner.
      • 23008
      "active scan"?
      Is that SMB, FTP, or scan-to-email? Those are your choices. What is this red flag?
      Do you have two network cables attached? The Voyager series has a separate NS30 scan card, completely unrelated to the print card.
      Maybe you're talking about SMB? Early versions of the NS30 firmware does not allow SMB scanning.
      Maybe you're trying to scan to Gmail? The voyager does not allow for SSL or TLS. Port 25 scanning only.
      We're going to need a little more information. =^..^=
      • raztech
        • Dec 2008
        • 88
        thanks for your interset in the subjet.
        let me tell you ...
        that we can't access to scan setup in the main menu (because the red flag on keyboard still exists).
        thanks again
          • 23008
          Maybe you can take a photo of this red flag? I might check to see that the scan card is enabled in U512. =^..^=
          • raztech
            • Dec 2008
            • 88
            thank you v.much for your help..
            i will send a photo as soon..
            thanks again
            best regards
            • robscopyr
              • Mar 2009
              • 54
              sounds like the scanner is not getting a signal from the network cable
              • copydocinc
                • Mar 2015
                • 263
                Maybe the network cable isn't even plugged in to the scanner outlet, as blackcat mentioned.
                Maybe this machine needs a scanner file utility installed on the computer too.
                • darry1322
                  • Oct 2010
                  • 817
                  Could be a dead hard drive. Can you use the document feeder at all?
