300i pausing during jobs
  • JDR
    • Jan 2015
    • 82
    Hi guys,
    i have an issue with a taskalfa 300i (counter arround 120k) which during duplex jobs (copy or print) pausing after 4 printed sheets and do nothing more.
    I can hear motors spining but no sheet is fed, no error or even jam codes...if i dont open any door, i think i would still waiting.
    If i do a job with more than 5 duplex, it won't work.
    I replaced engine PWB, dv unit, toner cartridge.
    I have noticed a wierd thing, i can't test any switch in U31, everything is grayed.
    any idea ?
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: 300i pausing during jobs
    Is the firmware up to date ?
    • JDR
      • Jan 2015
      • 82
      Yes it is.
      v9.00.010
      • Hose1cook
        Defective Technician
        • Jun 2008
        • 80
        Low Fuser temperature can cause this
        • JDR
          • Jan 2015
          • 82
          Low fuser that thermistors wouldnt see ? Wouldnt i have C6XXX erorrs ?
          • Hose1cook
            • Jun 2008
            • 80
            Sorry, should have been more specific. If the fuser temperature was lowered by even 5 degrees the machine will pause the copying process especially on duplex. I've seen techs lower the temp a few degrees and end up with the problem you describe, I've done it myself. Raise the temps 5 degrees and see if it works. Good Luck.
            • NeoMatrix
              Senior Tech.
              • 3514
              Assuming you are correct with the thermal timing issue.
              Would changing the media stock to thicker paper compensate for the drop in thermal raise timing ?
              I've seen similar on HP printers when the Fuser starts to fail.
              The fuser triggers a hault in the print process until the temperature returns to normal range.
              Sounds like this is a firmware issue. May be the fault should be passed on to the Kyocera Factory techs...?
              • JDR
                • Jan 2015
                • 82
                Hi
                Thank you all.
                Fuser temp was indeed lower than default.
                  • 22997
                  Thanks for following up. Congratulations! =^..^=
