FS 3920 DN Stuck in "Add Toner" Condition
  • Rmclean
    • Dec 2014
    • 4
    [Electrical] FS 3920 DN Stuck in "Add Toner" Condition
    I have an FS 3920 with 71K prints that will not come out of an add toner condition. I have replaced the development unit, toner cartridge, engine, and main pwb's, with no success. Any ideas?
    • 30247
    Re: FS 3920 DN Stuck in "Add Toner" Condition
    Check the pins on the dev unit
    • subaro
      • Oct 2010
      • 1274
      On the below right hand side of the machine is located the dev drive solenoid clutch and dev drive gear. A few times i have had to replace that gear. Not difficult to remove. You can check if the dev mag roller is turning by placing a mark on the edge of the mag roller.
      • CPI
        • May 2016
        • 8
        You can try going to service to developer and OK to start and press OK again to stop has worked before.
        Sent from my Z930L using Tapatalk
