Kyocera 3035 say jam after inserting cassette
  • tech28
    • Jun 2013
    • 434
    Had jamming problem from cassette #1, replaced feed assembly, now says " Remove paper jam from drawer 1 after inserting drawer. Remove cassette and goes to ready. Will feed fine from #2 and bypass. Anybody run into that?
    • 22973
    Re: Kyocera 3035 say jam after inserting cassette
    What jam code? What sensor(s) does it point to? Have you tested any of those sensors in U031? =^..^=
    • tech28
      • Jun 2013
      • 434
      Thank you for your response, but, I found the answer, you answered the same question somebody else had a couple of years ago. Lift motor/engine pwb. Will pursue those sugestions. Thanks.
      • daveh12
        • Jul 2012
        • 157
        Try a U906 before replacing lift motor, sometimes it's just disabled if paper gets stuck in and round cassette and gear of the lift motor.
