J000 on a Kyocera 255
  • JR2ALTA
    • Feb 2010
    • 2033
    I am currently boning up on the SIM 031 for this model. It's not so easy as it's a numerical testing system.
    I can't seem to jimmy any sensor fix this. It will go away for a while then reappear over time even when the machine is idling.
    I suppose the fuser would be the first thing to swap, but just wondering if anyone has any common J000 on these machines.
    Thanks in advance
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: J000 on a Kyocera 255
    OK so the SIM 031 actually looks easy. Almost too easy...
      • 23010
      If you're referring to the KM-255C, are you sure about that jam code? The Hanabi series uses 4 digit jam codes, i.e.: J0000
      • crazymugs
        • Sep 2013
        • 9
        If you are referring to the TASKalfa 255 that J000 speaks to an initial jam, The power is turned on when a sensor in the conveyingsystem is on. Check
        • JR2ALTA
          • Feb 2010
          • 2033
          Welding environment. Brown dust everywhere. SIM31 showed the Duplex sensor tripped. Clean it out.
          Thanks for your reply.
          • crazymugs
            • Sep 2013
            • 9
            Was this issue resolved?
