Help with driver info
  • scobo65
    • May 2012
    • 13
    Customer has FS-1016mfp and purchased new computer with windows 10. The mfp did not plug and play when hooked up with USB cable.
    Cant seem to find a correct driver to get installed. Tech support wasn't sure if this old machine is good with 10.Does anyone know if a driver
    is available ?
  • jhalfhide
    • Apr 2015
    • 451
    Re: Help with driver info
    As it's only a mono machine, I would just pick a driver of a newer Kyo that does work on Win10. Knowing Kyo, lots of the driver stuff is kept the same (such as tray designations and duplex commands).
    • copydocinc
      • Mar 2015
      • 263
      There is a driver download on their copystar.com website, but only has vista as the latest(32 and 64 bit) It might work.
      • richmods
        • Aug 2013
        • 91
        is available ?
        Kyocera has a universal PCL driver that covers up to WIN 8.1. Not sure if it will work on WIN 10 or not but worth a try. You may also want to try an older HP driver. If you dont have access to the universal driver let me know...I can send them to you.
          • 23006
          You might try the Win8.1 driver.
          I've had some luck recently with an Oki C5200 and a Win7 driver on a Win10 OS. No guarantees, but what do you have to lose? =^..^=
          • qbert69
            • Mar 2013
            • 1152
            I was ALSO thinking along the lines of a generic HP PCL driver!...I put a Kyo in place that had previously be an HP printer and the prints came out no problem with the HP Print Driver!
            COOL!
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • B0265
              • Jan 2007
              • 718
              If I remember correctly this old one is GDI only, I don't think it supports PCL.
