KM5050 Firmware Level
    • 30222
    What is the current level?
    I have 2GR 2000.035.002 2010.07.23
    • 23008
    Re: KM5050 Firmware Level
    That's the most recent: version 2.45a
    • boomer26
      Hey room!
      Question, how does one get the latest firmware for the KM-5050? I've reached out to the dealer we purchased the unit from and i've also contacted Kyocera directly to no avail.
      We're currently using 2GR_2000.033.001 and i'm looking for an SMTP setting that is not available. I'm looking for TLS for us to be able to use the scanner option with Office365.
      Thanks for any help!
        • 23008
        Originally posted by boomer26
        Hey room!
        It's not going to be available on any firmware level. That option just was not available at the time.
        • boomer26
          Thanks blackcat4866, i was afraid of that. Not sure what to do next to make this work? I'll keep trying. Thanks so much!
            • 23008
            There's a software solution out there called "Stunnel". Essentially it makes your scan to email into the proper format. I'm not sure how it works, but I have heard of successes. =^..^=
              • 30222
              Older Kyocera's DO NOT support SSL or TLS
              work around's will only create service calls for email failure's
              unless office365 supports an smtp relay or NON SSL or NON TLS format
              DON'T waste your time in a 3 party app.
              • stuckwithit
                • Jan 2015
                • 12
                BSM2 is right set up scan to folder and be done with it or sell them something newer.
