FS 3140+ jamming issue
  • Scottb
    • Apr 2013
    • 303
    So it looks like the jam code is a J31(although there were several JE0 jams also), since I am told that they never can find a jam. I am also told, that it usually is the first sheet of the job run. I was there and have installed new feed tires, and they called back within a week. I went back out there, but it ran fine while I was there, and I ran the hound out of it and then made them print several jobs before I left. About all that I can think of is either the cassette or maybe the lifter motor assy. What my question is has anyone seen this before on these models before I start ordering a bunch of parts.
    Scott
  • wragsdale
    • Jul 2014
    • 188
    Re: FS 3140+ jamming issue
    Check the rear and front door interlock switchs/actuators. JE0 can occur when the machine stops printing due to an interlock being in an open state.
    • lees
      • Apr 2011
      • 95
      Make sure the spring pick up is in place on the feed holder assy that keeps pressure down on the paper. Part # 302F906120.
      • Scottb
        • Apr 2013
        • 303
        Thanks I have seen that one before and was the first thing that I checked, and I am usually very carefull when I change the rollers now due to the first time losing the spring.
        • Scottb
          • Apr 2013
          • 303
          Thanks I wasnt sure if it had anything to do with the other jam code, but there were several. I will check that the switches next trip there.
          • crazymugs
            • Sep 2013
            • 9
            Is this machine on an extra paper tray? Do as wrapdale suggest and paper feed sensor in that extra tray. Let us know the outcome
            • Woody214
              • Oct 2015
              • 29
              Did you replace just the tires or the complete take up and feed assembly? I believe there is a one way bearing in the assembly which might occasionally slip. Also I did have one which had too much torque on the separation roller assembly and that caused intermittent jams.
              • Step
                Senior Technician
                • Sep 2015
                • 42
                Hi All
                I know this is an old thread but have the same issue on machine.
                want to make sure, the machine is on an extra paper tray PF-310+
                As crazymugs said need to check paper feed sensor, and interlock sensors as wragsdale suggested.
                Where is the interlock sensor situated ?
                On extra cassette or machine door ?
