kyocera km 5050 parts..used
  • jper34
    • Sep 2011
    • 225
    would anyone have a km 5050 parts machine..? as I need registration roller assem., my customer broke off idler gear bracket and gears, when you open/remove exit door assem., then remove inner assem.(x2 straps) one connector, then there is registration clutch and drive gears, 2 screws hold it in place.the plastic house, that holds the idler gear in place broke right off..I tried to melt the plastic in place, to hold idler gear in tact. but its only, kinda working..Im looking to find part number for the whole assem., right now, but if someone has a used part machine, that you could sell to me, it would be greatly appreciated !!!..Let me know...thanks !
    Jaime Perona
    Independent Copier Service
    Stonington, CT.06378
    when I find part number, I'll send forth..
    860-739-6950/ jper34@gmail.com
    • 23010
    Re: kyocera km 5050 parts..used
    Is this what you're looking for? Middle Feed Unit Assembly: 302GR93150
    • Intone
      • Apr 2015
      • 68
      try greater Philadelphia equipment, glen 1-215-788-7111, he may have the part from a used machine
