Greeting everyone
Have an issue with AirPrint on a customer's network. 2 TA 3051ci will publish the devices so you can print using Airprint from IOS devices (iPhone & Ipad). However, after about a minute, the devices won't show up again. It will only be visible again if you restart the NIC or the MFP. This happens to both machines. A twist to the situation, is there are a couple of HP inkjet printers that publish themselves and never drop off.
I have updated firmware on both mfps. No change.
I tested Airprint on my networks and they show up all the time, even if the MFP is in sleep mode.
Question is. Has anyone seen anything similar?
Thank You
Thank You
